I am preparing to have our master bed/bath/closet redone and kind of wish I saw this a few weeks ago. I think the contractor we got is reputable but this is kind of a small job for them…here’s hoping it works out.
That is a difficult thing. You are a good man, doing what is best for your loved ones.
I just stumbled onto this great carpentry tips video - https://www.youtube.com/watch?v=yeVK4EtdBso
So, the White Album. I mean classic, right? I have two copies. A very original British pressing in a top loader jacket that my (freaking awesome) son gifted me some years back, and a modern Giles Martin remix that my awesome wife bought me a few years later. I so very smugly thought the remix to be superior, because technology, yay!!!. But tonight I listened to them back to back, and got absolutely humbled. The original is SOOO much better, snaps and pops and all (a good cleaning is happening tout d’suite).
I mean, wow. Holy freaking wow.
It is indeed a great album, although after over 50 years of listening I still hate “Revolution 9”.
I own/have owned several versions on LP and CD: Oz and Japanese LPs, original and 2009 CD issues and the Giles Martin set with the Esher demo disc, which is a fascinating listen.
The Japanese LP has great sound and the vinyl is very quiet, which the Oz pressing isn’t; I prefer the Giles version to the original CD issue. But really, it doesn’t matter to me after 30s of listening, it’s just such a great record.
Of course, the poster looks much better in LP size and you can frame the band photos, not possible with the CD issues.
Point of trivia: the aircraft sound which opens the album is a Vickers Viscount turbo-prop.
Huh. Sounds like an actual jet. Interesting.
The Viscount used the Rolls Royce “Dart”, which was used in many aircraft of the period, including the Fokker F27 ‘Friendship’, HS748, DC-3 and even the P-51 Mustang (as the “Piper Enforcer”). It had a very distinctive sound which I can still remember.
The Viscount was a popular airliner which was used by many regional carriers and by various rock bands for touring: there are several photos of Hendrix, Led Zeppelin and others with it.
Ai bites me in the ass again. Was told I could swap out the EL34C tubes for some KT77 , nope . Smoke show after about 10 seconds of power on. Shut it down , put the EL34 tubes back in, left channel EL34 seems to power up , right channel is lights out with no one home. Shut it down. Might pull the bottom off tomorrow night after work and see where the magic smoke came from. Pissed
Sigh…
“Dear Nicholas,
Thank you for reaching out to us and for your interest in our EL34 tube amplifier!
Regarding your question: We do not recommend using KT77 tubes to replace the EL34 tubes in this specific amplifier.
Although KT77 shares a similar pinout layout with EL34 on paper, this amplifier utilizes a fixed cathode-bias Class-A circuit optimized specifically for the plate dissipation and bias operating points of standard EL34 tubes. Running KT77 in this design can cause incorrect bias drift and potential overheating, which our workshop does not support.
Safe, Direct-Drop-In Alternative Tubes:
Power Tubes (Direct Replacement): You can safely use 6CA7 tubes without any modifications (or KT66 if not driven at extremely high volume levels).
Preamp / Driver Tubes: You can upgrade the stock driver tubes directly to 6SN7 or CV181 for enhanced resolution and warmth.
Rectifier Tube: Compatible directly with 5U4G, 5Z3P, or 274B.
Please feel free to let us know if you have any questions about tube rolling or speaker matching!”
If you are lucky, it’s just a burnt cathode resistor. It’s probably paralleled with a cap, so check that too.
Appreciate Tom , Ill pop the bottom open tomorrow and see whats going on visually.
Upgrades to my guitar coming soon. Bought a pretty nice Ibanez RG from my friend Phil (50watthead on the PE board) with a Duncan JB pickup in the bridge, and an eBay special single coil wedged in the neck position. Took out the single coil, and ordered a Duncan Jazz model neck pup. Along with CTS pots, an orange drop cap, and rosewood volume and tone knobs. Work will commence this weekend to wire it all up, I just plain get home from work too tired and to late during the week.
Hell yeah! Love me some Ibanez![]()
Seymour Duncan isn’t to shabby either![]()
“Dear Nicholas,
Thank you so much for your follow-up, your mechanical expertise, and your incredible honesty and kindness! Customers like you make our work truly meaningful.
Measuring 270 ohms on both cathode resistors and seeing the Rubycon 470uF caps intact is very good news—it means the power supply and primary cathode stage did not suffer a catastrophic failure!
Our chief engineer reviewed the exact factory schematic for your amplifier. The 270Ω you measured perfectly matches our design (which uses two parallel 560Ω resistors in the cathode: $560Ω || 560Ω = 280Ω nominal).
Since your amplifier uses an Ultralinear topology (the screen grid Pin 4 connects directly to the output transformer tap), we can easily isolate the issue without powering the unit on.
Please keep the amplifier unplugged from AC power and try these two quick diagnostic steps:
Step 1: The Tube Swap (Simplest Check)
Swap the left and right EL34 tubes with each other.
Power on briefly. Does the problem switch to the opposite channel? If yes, the issue is simply a damaged EL34 tube, and the amplifier chassis is 100% fine.
Step 2: Cold Resistance Test on Output Transformer (With Multimeter, Unit Unplugged) If swapping tubes does not change the channel, measure the primary winding of the output transformer on the problem side with your multimeter set to Resistance (Ohms):
Measure between Pin 3 (Plate) of the EL34 socket and the 280V B+ line (positive terminal of capacitor C11).
Measure between Pin 4 (Screen Grid) of the EL34 socket and the 280V B+ line.
Compare these readings to the working channel.
If the readings match between both channels, the transformers and circuit are completely intact!
Please let us know what you find. If you need a replacement EL34 tube or any factory components, we are fully prepared to support you.
Best regards,
Alice”
Really good to hear of old fashioned, informed customer service.
All too often, I get apathy, ignorance, rudeness or belligerence when I make a legitimate complaint or ask a sensible question.
Those incompetents that did the bathroom couldn’t even get the toilet paper holder right. It is pulling out of the wall. Sigh. “Lucky” for us we have to rip out a bunch of the drywall anyways, so what’s one more little area to patch and paint? I ordered a weighted stand to use instead.
I find those sorts of things galling, as it really doesn’t take much more time to do the job properly.
Example: in our old house I had to take some doors off their hinges for repair.
What did I find? The idiot(s) had used nails, not screws, for the hinges, so I had to drill them out and the job turned into a major faff.
OK, that was freaking awesome. Is the destruction of the monster woofers vid out there as well?
