The Easiest CNC I've Ever Used
Watched that, very interesting. Ron E has something similar to check out too.
I’d like to see some unpaid reviews, but looks like it could be pretty cool if it’s reasonably priced
I have seen things like this before the problem is that they are not super accurate outside of a certan pocket. The innermost 25% of the cnc zone will probably work well the outer 75% will be less acurate.
The reward is that they are very cheap to manufacture. And if you are making artsy things that don’t require tight tolerance then it will be fun.
