The Triads - a 3 way bookshelf using the 8” Ciare HSG200-4, 5.75” Wavecor WF146WA06 mid and Peerless NE25 tweeter.
Cabinets are about .75cuft for the woofer tuned to 42hz. Three of my last four builds were 3cuft floorstanders, so my #1 requirement for my next build was that it be a bookshelf
Why this driver selection? Mainly to use up what I have on the shelf. I snagged the Ciare at InDIYana, but based on quick testing they’re really unhappy at 800hz. So I needed a mid that could easily play down to 300-500hz to play nice with the Ciare. The Wavecor was the best option for size and performance that I had on hand and met that requirement. Chose the tweeter primarily because it’s the smallest format I have and the closest sensitivity match to the other drivers. The cabinet is 20” tall and I only have about 21-22” of height where I’ll put them, so I simply couldn’t have fit a large format tweeter.
Got to have at least the cabinets finished before the weather turns so I can play with the crossover over the winter. This is where they sit, so as long as I dont hit any major speed bumps that should be doable
They also work in small enclosures. Ciare recommends like .55cuft for this driver, which is also what my design looked like based on manufacturer data. I ended up a little larger based on the measured parameters though as Fs was quite a bit higher than Ciare says. Still .75cuft vented for an 8” driver is pretty moderate
Driver holes machined, port rounded and driver chamfers cut. Currently feeling pretty good about getting the cabinets done enough at least for measurements prior to the weather changing. I was hoping to have them finished before winter, but we’ll see. As long as I can at least get measurements, I’ll be set
Really just need to make a couple braces for the rear of the midrange enclosure and run midrange wires into that chamber, then I’ll be ready to attach the front and rear baffles.
My wife gets medication delivered from Amazon that are temperature sensitive. They come packed with two sheets of this poly insulation. Which is pretty awesome because now I get free enclosure lining. However I’ve got more than I know to do with, so I’m excited to finally get to use some of the stockpile. Plan to use it to line and stuff/fill the enclosure for both the woofer and MR (MR will also get denim insulation)
Wires ran. Midrange enclosure rear braces installed. Midrange enclosure sealed with silicone. Poly sheet stuffed in the area I won’t be able to reach with the back attached, which is currently being done on the first enclosure
My goal with my builds is to try something new (to me) each time. Nothing ingenuous or Nobel worthy. Just something I haven’t tried before. On this project that is faceting the baffles.
I spent most of the week pondering how I was going to cut them. The belt for my table saw broke and I haven’t bothered to replace it because I absolutely hate my table saw. So that was out. Next best option was my tack saw, but the track runs on the left of the cut which means it’d be hanging off the enclosure. Spent most of the week thinking about how I was going to accomplish it. Ended up being a pretty simple solution.
I used a scrap piece of plywood that was a bit larger than the enclosure. I clamped the track to the plywood and then ran a cut down the middle of it that stopped about 6” from each end with the blade at the appropriate angle to create a guide. Then I lined that guide cut up with the markings on the enclosure and clamped the plywood to it.
My goal with the facet was to get as close to the tweeter and mid as possible. The downside to this approach is that I lost .75” of cut depth. I figured this solution out pretty last minute so I just used what I had on hand. If I ever do this again I’ll grab some 1/4” or even 1/8” material to use as the base to gain back some of the cut depth. The saw wouldn’t have been able to make the entire depth of the cut regardless, but it would’ve saved me some more time manually sawing.
Originally my plan was to veneer these. But since I had to do so much sanding of the facet I don’t think the edges are sharp enough, so they’ll probable be either painted or Duratexed.
This is how they sit as of now. I’m going to facet the bottom corners also. Now that they’re getting sprayed or rolled I might even 45 the remaining edges at the top, bottom and sides
The way I fix goofed corners is to get a wood scrap and glue it on, then I can shave and sand it back to the needed shape. Something small like that could probably just slice the edge off some plywood with a box cutter and glue it on. I just use masking tape to hold it while the glue dries. Doesn’t take much
Good idea Drew! I didn’t have my heart set on veneering these as I was just going to use up scrap I had left over. But that’s a nice tip to use in the future.
No speaker build would be completely without a colossal screw up. Absentmindedly had the track saw on the wrong axis when I made the cut . Luckily I caught it before completing the cut as it was deep enough to have cut the whole corner off and turned this into an infinite baffle. With a little sanding this should turn out to be a pretty much invisible. Still irks me though.
