4thtry's 2026 InDIYana theme project - Divide and Conquer
I only got to hear them once, but thought they presented well. I tend to like a bit of zing to a speaker and thought yours sounded fine, IMO of course. Maybe the ol BBC dip would be a good idea in it’s regard?
Revised xovers based on Indy feedback.
  1. Eliminated the big 36mH inductor and boosted/flattened output from 50 to 250Hz.
  2. Raised lower xover to 270Hz (originally 200Hz).
  3. Lowered the upper xover to 2200Hz (originally 3200Hz).
  4. Reduced output of RD40 from 1 to 5kHz.
  5. BBC dip from 1-7kHz, pulled on axis response down by roughly 2-3dB.
I have not installed the new parts yet, but if this change makes them sound too dark I’ll do some more tweaking. My speakers definitely sounded too bright and harsh at Indy. And they did not have enough energy in the 100 to 500Hz area. Will see how this goes.
Overlay of old verses new on-axis response:
New on axis response:
Horizontal directivity:
Impedance: Heats amp up good, but still OK.
Filter network:
CTA2034:
Tweeter xover board mods done.
Before mod:
After mod:
Before moving on to the midrange board mods, I ran an impedance curve on the tweeter + tweeter xover boards alone. Then verified the curve against my VituixCAD model with the mid and woofer sections temporarily disconnected. I get an almost perfect match, so now I know that I don’t have any stupid wiring mistakes or cold solder joints. I always like to do this type of verification as I go along, section by section, because it makes it much easier to track down problems later on. (I’ll add this debugging procedure to the VCAD tips and tricks thread, if anyone thinks that this is a worthwhile idea.)
DATS V2 sweep, tweeter and tweeter xover parts alone:
VituixCAD modelled impedance, tweeter and tweeter xover parts alone:
Midrange xover mod completed. My DATS V2 validation impedance curve measurement is a very good match to the VituixCAD model, so everything looks free of cold solder joints or inadvertent wiring screw ups.
Woofer xover mod is now complete:
While I had the cabinet open, I added a couple wires that connect the tweeter board back to the extra pair of unused banana jacks on the back of the midrange cabinets. These jacks were left over from a previous build, so I decided to press them back into service.
Then I made a small dual banana plug-in type module that consists of a BBC dip + tweeter notch/contour circuit. So now I can modify the tonal balance by quickly changing parts on this small module and then hot swapping the module in and out as I listen to music or run frequency sweeps.
I am currently doing A/B/C listening comparisons swapping between Wolf’s Nephlia speakers, my pair of Sennheiser HD600 headphones, and the Divide and Conquer speakers. I’m using various tweeter plug-in modules to adjust the tonal balance. Current plug-in module uses a 23 ohm shunt and a .05mH/3.3ohm/3uF series notch. I think I’m beginning to zero in on the sound that I am looking for. I’m also running FR sweeps using the moving mic method as I go along.
Decided to dress them up a little with some upside down crowne moulding. This is the stuff sold in 8 ft lengths here: https://www.lowes.com/pd/Ornamental-2-13-32-in-x-8-ft-White-Hard-Unfinished-Rope-Crown-Moulding-Actual-2-343-in-x-8-ft/1001107586#no_universal_links
I cut it up into short lengths and dry fitted them for the photos. Don’t know what wood this is, but it is a hardwood that is very light in color. Seems to take stain well, not as soft or blotchy looking like pine can be. About the same density as some of the light colored poplar that I have used in the past, but it is not poplar. Softer than maple. Plan is to either stain the wood with several coats of red chestnut and finish with wipe on poly. If that does not look good, I’ll sand them down and spray them semi-gloss black.
I left the back open to allow space for my plug-in tweeter contour modules. Also, I want to be able to remove the back to get at the drivers and crossovers. From the front, you can’t see the contour module or missing moulding unless you walk beyond 45 degrees.
Alder wood?
Makes sense. Alder is a relatively cheap, soft hardwood, which fits with the pricing and hardness. Lowes calls it “Ceiling Crown” “Natural Wood” on the store price label. On the website, they call it “hardwood.” I guess Alder is technically classified as a hardwood, even though it is fairly soft.
I put on a heavy coat of red chestnut stain today. Will give them a second coat tomorrow and then a third on Thursday. I’ll be trying to achieve a deep, reddish, burgundy tone to match the rest of the speaker. Just enough grain showing through so that it looks like real wood instead of paint. Finish with 3 or 4 coats of wipe on poly.
This is what the moulding looks like after 3 coats of red chestnut. I just set the moulding parts in place for some of the photos (no glue yet). (They should look much better once I get the wipe on poly part done later).
I wiped the stain on fairly thick with a foam brush, let it sit for 3 minutes, then wiped the excess off with a clean rag. The deep, reddish tone gets slightly darker with each application, so I might give them another coat or two for good measure. The stain takes a long time to cure, so I will probably wait at least a week before finishing them with wipe on poly.
I’ve generally found that when the stain finally leaves one’s fingers, its ok to poly…
edit: I’m talking at least 5 days of washing… ha
I experimented with some left over moulding, letting the red chestnut stain dry for 24 hours, then applied wipe on poly with a clean rag. A small amount of the red chestnut stain color actually wiped off as I applied the poly. So I know that 24 hours is not enough.
This is Varathane premium wood stain, red chestnut #254, interior. The can label lists mineral spirits or paint thinner for cleanup, so it is an oil based stain. Also from the label: “. . . allow to dry for 8 hours when applying an oil-based finish or 24 hours when applying a water-based finish.”
OK, got it. That sounds about right. However, I was wearing rubber gloves during the staining process, so I didn’t get any on my fingers! :grin:
Update: After several weeks of LMT (listen, measure, tweak), I think I have something that sounds much better than before. Very close to the sound of my HD600 headphones and Wolf’s Nephlia loudspeakers in direct A/B switching comparisons. At least to my ears. So I think I will quit at this point and call them done. Here are a few graphs showing the revised VCAD model and some 2.3 meter distance on-axis measurements that seem to confirm (or validate) the model.
Revised VCAD 6 pack: New targets and xover points:
Modelled on-design axis frequency response: (aspect ratio of 20dB/decade). The curve matches a 0.3dB/octave downward slope from 100 to 10000Hz. The reference axis is -20 degrees horizontal, so I will be setting up the speakers to face directly ahead; not toed in. The 5.6kHz RD40 resonance is suppressed by about 26dB.
CTA-2034 model: The target for PIR is about 0.9dB/octave and the target for PR is about -1.5dB/octave. Aspect ratio is 20dB/decade. Directivity curve is flat from about 1 to 5kHz, then narrows above 5kHz. Smooth transitions this time around instead of the bumpy looking mess that I had previously:
Revised Impedance model: Dips down to about 3 ohms in a couple spots. Amplifier gets nice and toasty but does not complain.
Revised horizontal directivity heat map: Seems a bit smoother and consistent than previously.
Revised vertical directivity heat map: Vertical directivity is much wider than the original design, but still fairly narrow. I experience very little tonal balance shift moving up or down over a listening height of 30 to 50 inches or so. When I stand up, however, the response dips about 2 to 3dB in the 1 to 2.5kHz range (everything else remains the same). My ears are at about 65 inches when standing. Kind of like a BBC dip when standing, which is not objectionable.
Preference rating: For what it’s worth, here is the final preference rating chart in VCAD. I don’t pay much attention to these numbers as I design, but I always check them over when I get done. (They are a tool for evaluation; nothing more). On some revisions, the rating peaked out as high as 8.9, but I actually preferred the sound of a revision that had a slightly lower score. In any event, these numbers were generated using the default set of equations in VituixCAD version 2.0.135.2, dated 4-25-26.
2.3 meter on-design-axis validation measurement: This first one is using my dual channel setup (calibrated Sonarworks Sound ID mic, Steinberg UR22 MKII, REW software). The speaker was sitting on the floor for this measurement and was located 4 feet from the front wall and about 6 to 7 feet from each side wall. Vaulted ceiling. I moved as much junk out of the way as I could to keep reflections to a minimum. Psychoacoustic smoothing was used. Aspect ratio is 25dB/decade
OmniMic 2.3 meter on-design-axis measurements: I set up OmniMic for a sanity check measurement with the loudspeaker and mic tip in the same positions as before. The first graph is shown at 40dB/decade. The 2nd graph is the same except it is shown at OmniMic’s default aspect ratio of about 70dB/decade. Gate was 10ms and smoothing was 1/12th.
You definitely put in some work on those speakers! I thought they sounded pretty good at Indy, I can only imagine they are even better, hope to hear them again in their new form. To bad there’s no “jam room” at PE this year.
Thanks, Eric. Your speakers sounded really good at Indy as well. And much better looking than mine. Too bad about the jam room, I know quite a few people really liked that feature. Hopefully they will still have a photo booth set up for taking studio quality glamour shots of our finished speakers.
I wasn’t happy with the red chestnut stain. It clashed too much with the other reddish colors. So I painted the crowne moulding semi-gloss black and glued them into position. I think it looks better now. Please note that the apparent orange cast on the midrange cabs does not look that orange in person verses the deeper reddish cast on the bass bin edges. When viewed in person, the midrange cabs have a deeper reddish cast. I think the cell phone camera’s auto color balance is making the color mis-match look a little bit worse than it actually is.
I’d agree, the difference is subtle in person. Glad you went with the black on the crown moulding.
All done and ready to go.
