So um…this ‘simple’ project kind of blew up.
Maybe it’s because I didn’t sleep much last night, but I started thinking about other possibilities. Perhaps I shall have more than one design ready to go depending on parts availability? I’m am now considering making all of the following designs as “ready to manufacture”. Volume needs to stick around 8-10L total with a baffle no taller than ~12" in order to fit on my printer. Width can vary, but 7-8" seems most likely. If possible, I will try to use the same cabinet for each build. Crossovers need to be reasonably simple and elegant to fit in the cabs.
Mechano23 - CAD work nearly complete. New test baffle complete and looking like it may be the final version. Awaiting crossover PCB manufacture and arrival before finalizing the crossover brace(s). One set of tweeters and woofers in hand, so it’d be silly to not make at least one, but both parts are readily available and the BOM crossover parts are only around $100 USD shipped (sourced at Solen). I don’t think I’ll stray too much away from that design and will probably make several of these since I ordered 10 crossover boards (they were cheap and the minimum orders were either 5 or 10 so it made sense). This is kind of the baseline for comparison to the others, and costs around $162 for a pair of tweeters/woofers (Madisound).
Gifties - SB Acoustics SB26ADC tweeter in an augerpro elliptical waveguide and Midwest Audio Club MAC-05 midwoofer. Note I chose the aluminum (ADC) tweeter for this pairing because I was concerned the ceramic (CDC) tweeter color would not match the MAC-05 silver well. Part of the rationale for this tweeter is the ready availability of various elliptical waveguides from augerpro’s website - a round waveguide may be too ‘tall’ given the height restriction of the speaker. My intent is to integrate the waveguide into the baffle as one piece and also have a version where the waveguide is simply attached to the baffle. Why? Mostly for color options. I have a weird intent to make a bright green cabinet, bright yellow baffle/rear, and bright orange waveguide/port. There will probably also be a white/light pink/light blue variant, among others. Anyway, I confirmed I have two MAC-05 drivers and will acquire some more shortly. I do not have any of the ADC tweeters, but they seem to have high availability. Around $166 USD for a pair of woofers and tweeters (Madisound and Jule Fidelity), should be a great value.
Gifties Extreme - SB Acoustics SB26CDC tweeter in an augerpro elliptical waveguide and Cinergy / Denovo Audio Anarchy 558 midwoofer. Same as above, probably make two different baffles here. Should be simple enough. I seem to have six 558 midwoofers (with more apparently available at Cinergy Audio for $66) and four of the 554. I’m also pretty sure I have a pair of the CDC tweeters lying around, though I didn’t look for them this morning (and they may be dedicated to another project already). Basically $132 for a pair of these (for 2x tweeters, Madisound) unless I decide to make more than three sets, in which case it would be around $264 per pair. This would be the most expensive of the three variants if starting from scratch.
Gifties Supreme - Peerless DA25TX tweeter and FaitalPRO 5FE12X midwoofer. The 5FE120 has a sort of truncated bracket, the 5FE125 is round, either is easy with 3D printed baffles so it’s mostly just a preference thing…and what will fit on the baffle given the large size of the Peerless mounting plate. I looked through my parts this morning and found 11 DA25TX tweeters, so all I’d need are the midbasses, which seem to have high availability at the time of this writing. Since I have 11 tweeters, I considered trying to tear one apart to see about making it fit one of augerpro’s waveguides. Is that worth the effort given the stock performance? I’m open to thoughts. Since I have so many tweeters it’d just be the cost of the woofers, so the ‘Supreme’ would actually be the most affordable of any of these at $110 for a pair of the woofers (US Speaker), or $222 if starting from scratch (US Speaker / Parts Express).
So that’s a lot, but I’ll be indoors a lot too (due to the pending heat) and the CAD work is relatively simple, just time consuming. So then it’s just the measurements and crossover work, which could be fun!
