Another " Because she let me"
So being a very frugal guy, such are some of you. I try to use what I have. In this case what I was given at Grand Rapids. Thanks to Ken and Madisound, four Eminence alpha lite 16 Ohm 6.5 mids and 2 scan speak partially horn loaded dome tweets. I recall Ben stating that they were 95 db in a MTM. I said that I would put them them all in parallel and shoot for 101 Db. Watts are cheap but it’s different in this case because I do not know what the heck I am going to do with this creation. Because I am making SPL a priority, sound Quality next. I have a Dayton 4x100 KAB laying around. I have fountek woofers, I have 5/8 OSB, I have 1/4 inch rubber floor covering. I need to buy some more foundation coating. One channel drives the arms, the remaining three channels each will drive two 8 ohm woofers in parallel. Two front facing, two dual opposed and two down firing. The cabinet will be minimal. Industrial.
because she let me.pdf (303.5 KB)
Sorry, I am an analog guy in a digital world. That was not the correct PDF
I read your post title as “because she left me” and was going to ask for her number. Just joking.
Flattering response for his wife . . .
That combo of mids and horn loaded dome tweeters would work well as small PA/DJ mains, to be combined with a 12 or 15" vented subwoofer and used wherever a loud party or a bar band performance needs to happen.
That reminds me of " Analog Kid" and " Digital Man" from Rush.:grin:
I am using what I have on the shelf.
Armpit terminus bot is coming next year. A not portable bluetooth speaker.
Armpit terminus Bot.pdf (291.4 KB)
