DIY fever here!
Ever since I’ve gotten back from IowaDIY I’ve had the fever to build some DIY speakers. So while I’m building my normal commercial stuff I built/finished a few DIY speakers.
This has been my ongoing bookshelf open baffle project. It’s coming to a close. I’m very happy so far with the results.
You really should move the Lpad to after a highpass (notch?) to reduce thermal stress on the resistors, or split them to series before and parallel resistor after the highpass. This or increase their power handling or add a series highpass cap before the Lpad.
There’s a 80mfd cap before the l-pad just not pictured. Moving the notch makes a mess of the FR so that’s staying.
I know common knowledge says move the resistors after the filter. Other than the heat I have never heard an arguement for moving it after. Going by the data sheets the resistors should be fine in their wattage range and should be the lowest distortion component in the crossover. I have a hard time finding any solid data on capacitors being used in higher voltage vs lower voltage when being used for crossover compinents. Inductors are not a hard science so there won’t be much hard data. We know they store power in the magnetic field-less power, less field, less distortion.
I would love to see some data that is contridictory. If it truely is that we are trying to keep the heat out then we really just need to start stacking resistors.
I’m also way to stubborn for “just trust me bro”.
Reduced overall sensitivity?
Sensitivity would be un-affected. If the Lpad used to reduce the voltage before the capacitors the capacitor should have a faster dv/dt literally increasing the “speed” of the capacitor.
In short, the ‘after the capacitor / just before the driver’ placement is what allows the L-pad to do its two jobs at once: (1) reduce level (while minimizing unnecessary power dissipation) and (2) present a more stable, predictable impedance to the high-pass filter. That is the main reason it is the standard recommendation when you want the filter to behave as designed.
Your mileage may vary… as resistor before capacitor may present a better fit / frequency tilt.
In my (admittedly thin) experience, placing the L-Pad before or after the rest of the XO changes the FR more than just level. I’ve never liked an Lpad after the XO. At all. I’ve been ok with one before, but my own preference is a split pad, resistor in series in front and resistor in parallel after the rest of the XO. I’m reasonably sure that there are multiple reasons why I’m wrong, but that’s what I generally do.
More often than not, Mark, my lpads end up split like that as well.
I thought most of the issue being discussed was the parallel resistor before the circuit, not the series resistor. oah well
I think it was you who taught me that a parallel resistor after the crossover can help tamp down the impedance spike of a tweeter and help roll-off below fc.
The parallel resistor is the component that causes my concern for such a layout. However, some other people feel the resistor shouldn’t be in series out front either. I feel it’s fine.
I am learning that in VCAD I can quickly compare crossover variants with different tweeter attenuation methods to see what I like best.
I’m pretty much done. I will be playing with the l-pad levels for a couple days yet. The FR is a little choppy but it does smooth a little off axis. I’m impressed with low end from these and they do get pretty loud before the fart noises presents itself.
0,15,30,45,60,75,90 degrees
Distortion at 8” on Sub
Distortion on coaxial at 8”
:grinning_face_with_smiling_eyes: Looks flatter than most of my builds.
