So I’ve mostly completed the new 3D model and have several parts printed. Before doing that I asked around on the Bambu forums to see what could be done about the warping I was getting on the corners of the larger parts. They were very helpful! I don’t know if any one of these changes did it, but the combination certainly helped significantly.
Dry the filament for 24 hours. This was a step I normally do for just 6-12 hours for the nicer projects I do with PETG (usually not at all for PLA given how dry it is here in southern NV). I skipped this step entirely for the prototype prints, but this time I gave it the full 24 hours.
Increase the bed temperature from the stock value of 70C. I chose 75C, no idea if it’s doing anything…but maybe?
Turn DOWN the fans to keep heat in the chamber relatively high. I could also choose to control the temperature directly but that didn’t seem to be necessary - usually that’s only for the advanced filaments that need very high temps.
Design fix #1 - Chamfer the entirety of the part that would otherwise make contact with the bed. I used a 2mm chamfer and made it a feature. This I had done before even asking at Bambu and it definitely helped a little. Someone here might have made this suggestion.
Design fix #2 - Hard, sharp corners (as those seen on the bottom of the picture) are subject to the worst warping due to high stress on small points. The fix is to usually just round off the corners. I did this on the top, but for the bottom I chopped off the corner then rounded the remaining edges.
Design fix #3 - Long, uninterrupted stretches that make contact with the bed are subject to the most stress. To alleviate this issue, you need to break up those stretches. I made some small, shallow circles on the backside of the part to do this. If the part were much more solid (i.e. greater than the 25% infill I used) It may be prudent to have the cylinder go nearly the whole way through the part and hide it with exterior skin on each side. This was unnecessary for my situation.
Design fix #4 (NOT IMPLEMENTED) - One could also ‘ridge’ the edges of the design with tiny curves. I didn’t care for how that looked so I did not do this.
Here’s how the back of the rear baffle looks. I haven’t actually printed this part yet but the front baffle and mid chamber printed flawlessly and used the same techniques.
I also did a couple things differently on this build.
Previously the bolt holes were inset by a least 12-16mm compared to how they are above, where they are relatively close to the outer edge. This was because they actually used bolts to hold everything together and you need to be able to access the bolt head. This time I’m using threaded rod that extends all the way through the speaker. I used M8 heat inserts on the back of the baffle (you can’t see them from the front), screwed M8 threaded rod into it, and on the backside there will be small steel thumbscrews (not like those phenolic ones shown below) that’ll cap everything off. There’s a little more to it on the bottom where you can’t use threaded rod due to the placement of the passive radiator, but in general this is the way forward. I have short threaded rod and temporary knobs holding together the mid cabinet for further testing. Once the new woofer compartment is done I’ll use the longer threaded rod in all positions.
You can also see in both images four T-slot insets. This is to aid with alignment because I no longer have a groove for the gaskets. Gaskets are just flat now.The T-slots on the woofer compartment are for braces which will just extend past the cabinet a few millimeters through the gasket and into the baffle.
Something that I should have noted in the first build is the audio from the woofer vibrated the panel ‘shared’ between the mid compartment and woofer compartment. The panel vibrates (and presumably makes some level of noise) and audio also passes through the panel itself. That’s obviously no good, so I’m taking a few steps to try and alleviate that issue. Hence the Siless-branded stuff shown below (it’s also inside the mid compartment). Because of this I’m not sure where exactly the crossover will now go, but we’ll see how big and complex it gets and go from there. It may be cool to create a whole ‘base’ for the speaker that the crossover fits in and the speaker rests upon. If time (and filament!) allows, of course.
Shown below is the back of the mid compartment with temporary ‘short’ (~6") threaded rod and knobs holding it together.
Welp, I don’t think I can get these done on time. I had made a change an hoped for the best but…it did not work out.
I’m something of a coaxial guy and have quite a few scattered around the office right now. Among those were two pairs of newcomers - the SB15BAC30-8-COAX and SB17BAC35-8-COAX from SB Acoustics. The latter only recently arrived so I decided I would make baffles for both and see what I see. What I saw was, well, disappointing.
SB17 - the test sample just did not sound good and the mid/tweeter just don’t line up well. Making a crossover would likely push one (or both) too far. I did not test the other sample and it remains NIB.
SB15 - one of the samples was damaged, the tweeter terminals were partially torn off. I thought it looked connected still but that does not seem to be the case. The other one really doesn’t measure significantly better than the SB17 and, despite the testing done, I swear it’s rubbing a bit.
I’m disappointed enough that I’ll send all four of them (including the busted one, if you want it, maybe it can be repaired) to someone for $150 shipped.
I’m still working on the Satori / Peerless combination so we’ll see how that goes. I’ll be at Iowa either way, but not bringing something would be a bit disappointing.
Yeah, that is disappointing. But if it makes you feel any better, you took one for the team as there are likely a few here wondering about those. I know I was.
I was still pretty salty when I first posted about the SB Acoustics coaxials so I decided I’d show a little data for the SB17BAC35-8-COAX so you can draw your own conclusions. These measurements were taken around 8" away from the baffle, centered on each driver for the tests. After another look I’m still pretty disappointed but they can probably sing with the right touch. Driver was in a small sealed box with denim fill - probably too small for the SB17, but I’m not sure I’d try to use it without a woofer.
I’d show the SB15 too but apparently I saved over the data files (my bad) and they’re boxed up heading to a new home. I will say the SB15 has a very similar profile overall, though the mid plays a little higher.
Note: these are single channel measurements and I am an amateur when it comes to measuring speakers. I’m working on improving the setup (and my experience!) but wanted ya’ll to know just in case there is something showing up here that could be due to inexperience.
Edit: I deleted the distortion measurements as there was definitely something wrong with my setup. I don’t want folks to get the wrong impression.Thank you to those who reached out! I’ll leave up the frequency response for now as I believe it to be mostly correct.
The feel I got when looking at alot of coaxials is they are never going to “look good” on-axis. Yet they typically smooth out off axis, and sound better than the on-axis graphs would indicate.
I think I remember someone pitching a fit about the tweeter sensitivity on these? But I never understood their stance. Baffle step adjustments would knock down the woofer sensitivity anyway.
I’m guessing by 8" you mean mic was 8" away? The super low distortion numbers and flat lower region in the woofer measurement would lead me to believe so.
This is very true! However, the off-axis response really didn’t smooth out that much, IIRC. That said, they definitely ‘sounded’ better off-axis. I’ll try to take a look at that later today, assuming I didn’t save over that too!
Yes, 8" distance between mic and source. I ‘should’ have 1m measurements as well.
Always open to critical input btw, so if this isn’t useful or is misleading or something I’d like to know. I always felt this was a nice in-between measurement to get a basic feel for drivers. But as you mention, maybe not ideal for coaxials without additional off-axis input.
A larger diameter coaxial should start beaming at lower freqs than small ones right?
If so, a 10 or 12" coax will produce better directivity and less IMD than a smaller one . . . which is my thinking for going back to a 10" XO’d to a 12" woofer XO’d to a powered sub.
(Crap I guess I hit edit instead of reply above. That was strange. Let me try to fix.. If I can remember exactly what I said above to put it back.)
Unless I’m mistaken, “Beaming” is due to the distances involved from one side of a radiator to the other side. This distance creates a time delay that grows farther off axis and creates cancelation.
A coaxial has a tweeter in the center of the cone. The tweeter would be unaffected by this, until farther up the frequency range, since it is a smaller radiator
