I’m looking for a surface mount horn loaded tweeter.
I’m trying to find one that is surface mounted, not flush mounted where I have to countersink the faceplate.
The seos waveguide has a roundover on the edges and is less friendly to flush mounting.. though some folks do, at least partially.
Out of stock
3D printing a waveguide an option? For any of Auguerpro’s/Somasonus, the file could probably be tweaked to gradually approach the baffle and surface mount it.
Also available in white
I suppose square/rectangle shapes have a chance to reduce and spread out the diffraction effects across the passband a bit. Better than round at least.
But if you are lazy like me.. any tweeter can be a surface mount tweeter
Embrace the DGAF.
Beston RT003C doesn’t require recessed mount.
I have used the Rt002A surface-mounted and liked it a lot.
The Rt002A looks like an interesting tweeter. I need one that cross lower and a bit larger flange. (104mm-110mm)
I have a pair of those I’ll let go at a great price.
If they sound as good as there little brother you should use them…
I keep casting about for ideas, but keep stonewalling to be honest.
