InDIYana 2026 and theme continued
Working on it….
I have never participated in the theme challenge. So I came up with an idea that utilizes drivers on the shelf. Our TV sits in an alcove that formerly was exterior french doors. There is about 4.25 inches of space on each side of the TV. The depth of the alcove is 9 inches in this area. These will be painted black with black cloth stretched around it. I will probably leave the cloth off for INDIY for proper nerding. The side firing woofers and front facing mids will be wired parallel. I plan to first attempt 2nd order acoustic slopes. The enclosure is a TL with a ratio of 8. I may need to put in a resistive vent for the mid enclosure, but I doubt it will be necessary. It wont be an audiophile speaker but it might be better than most sound bars. I will need to buy an AMP. to power these. Any recommendations? Fosi MC331?
TV speakers Vertical pair.pdf (158.4 KB)
Pretty cool design. Should sound good for the drivers you are using.
Dates are confirmed!!
May 15-16 (Friday-Saturday) 2026!
There were many other obstacles to avoid this year, so mid-May it is!
I plan on attending Axpona for a long weekend, but am going to try and get to Indy as well.
Didn’t think you’d be coming, JR! It will be good to have you present again.
Room and flights booked. See you guys in May.
Is there a discount code for the Hotel this year?
I prolly just didn’t see it..
Yes, I have to update the website with the info, but here is the link now for those chomping the bit….
https://www.hilton.com/en/book/reservation/deeplink/?ctyhocn=FWADPHX&groupCode=CHHDSB&arrivaldate=2026-05-15&departuredate=2026-05-17&cid=OM,WW,HILTONLINK,EN,DirectLink&fromId=HILTONLINKDIRECT,
Currently updating website…
@wolf note: the webpage still says 2025
and thank you for all the effort you put in to organizing.
Probably the title… I’ll get it…..
What InDIYana contorts us to do - wonder if i can get the inductors to dance from interference
With enough power, for sure.
Is it time to make our entry reservations? Muah, 1 theme and 1 non-theme bookshelf.
I have you on the list, Tim, but I’ll change your entry to reflect this.
Been focused on the new job for a while. I got the green light from the better half to build something if I wanted to. Gotta decide if I think I can pull off something between now and then.
I just started last week, YOU CAN DO IT!
(must say in a Rob Schneider voice).
:slight_smile:
I won’t have a theme build this time, but I’m trying to get the Inq’ playable by then.
What’s up with the electrical tape wrapped around the ends of your Jantzen P-core inductor?
