Okay, wow- what a lot of things I did today to try and isolate or find the sibilance issue for these tweeters. I even mocked up a secondary circuit to mimic the xover on the tweeter and measure various things to see if they were the cause.
Here’s whare I started….
I first measured the system as a whole to get the followup HD/FR verification the simulation worked as planned. No concerns were found here. Then I tried various things to track down what was causing the HD curves.
I had a hunch the 6.2 ohm Lynk MOX resistor across the tweeter for both level and Fs compensation might be the culprit. I measured the Lynk and 2 other resistors for comparison, but none showed any discrepancies far enough departed from the others in terms of FR or HD. I still think the Lynk could at least partially be the culprit, as I could not measure the difference in the Drottnar project either via HD/FR means, however, by ear it was very apparent to me.
I tried the different caps on the installed switch in the xover as intended, and I could not get any caps to measure differently. I’m not surprised, as I have not yet been able to measure differences even though I feel they have audible differences.
I then noticed the already seen HD signature of the tweeter. I measured it alone, and I feel for the most part that the tweeter is the main cause of the HD signature. The curves are -45dB or lower, so below 1%. However, the 3rd order rises above the 2nd order at one point where the 2nd order takes a large nose dive and then rebounds.
No changing of the above checks or tests affected the overall HD curves much if at all, but I think that and the possible Lynk issue is my next step. So, I will replace the 6.2 ohm Lynk resistors with as close as possible other type resistors just to see if that helps. If it does not, then I have to tailor the upper treble response of the tweeters to suit me.
