The target roll off for the rear firing tweeter appears to be about 3kHz or so. Did you experiment with moving this roll off point either up or down to see how it affected the sound?
I did not play with that from a listening standpoint. The tweeter is a 3/4", so it can’t go too low. If it goes much lower, you could see it adding to the front signal. All the benefits I had read about were related to the rear wall reflections. I crossed it to have all of the energy firing to the back of the speaker. I also needed an 8ohm tweeter for this to work. I tried a 4ohm tweeter, and there was no way to keep the impedance high enough. That really limited my options.
After more listening, I ended up lowering the output of the rear tweeter and also cutting off the low end a bit more.
Too bad we can’t print the traces as well - looks good though!
No kidding!!!
23 min in, they print with solder.
These guys and this whole build is nothing short of fucking amazing!!!
I can’t recommend enough to watch the whole series. It’s incredible the level of work they do to this car. Not to mention the humor and music involved.
That’s pretty damn brilliant!
The vid is 2 years old so I suspect there are more commercially available copies of this tech available?
