Shawn A and I have started a rebuild of my 8” 2-ways that didn’t turn out as well as they shoulda.
Part of this was the Hi-Vi F8’s behavior at 1Khz. Most was due to an ill-advised EBS alignment. Now, EBS alignments do have their place, such as with small sat speakers and a high pass XO from an integrated amp or receiver to tame/flatten them and extend excursion support to the cone. They just don’t work too well by themselves. I had to teach myself that. It looked too good on paper, and was.
The OP was a 2-Way 8 with the Hi-Vi F8 and the Seas 27TDFC. The new project is still the F8 and 27TDFC with an added SB12MNRX2-25-4. The SB appears positively Scan-Speak grade in sims and for a 4” mid that can work to 300Hz and is sensitive, reasonably priced.
The new enclosure is better sized and looks like a 70’s - 80’s “monitor” size stand-mounted speaker. App. 1.3 cubic feet or so exterior.
With both original issues fixed, we’re hoping for some goodness.
New stuff tried in the project - usefulness to be determined.
Hy-Tech SC1000 Acoustic insulating Paint (yeah, I know, but the stuff is used industrially for fan manifolds so I just had to see…
) Woofer chamber got two thick coats and the mid/tweeter chamber received three extra-thick ones. Consistency of extra thick whipping cream. Insulating material is small vacuum-filled spheres floating in the paint. Jury is out.
1.25” Sonic Barrier pads - warning, contains lead so you have to either use it all (recommended due to high cost), or haz-mat the scraps (not recommended due to high cost). This stuff appears expensively bad-ass but other, less costly methods may be just as good.
Pics will follow when I get them off the phone - Shawn will elaborate on the XO.
Cheers / Robert
