Smaller 150uF poly cap
Will keep you all posted
@Tom_S do you have this one? Thought i saw somehting like this in one of your builds?
Yes - same one. Not sure how accurate mine really is, but here’s what I’m seeing comparing it with my DATS V3. Cap is a 56uf Clarity Cap
Wow, huge difference! Good to know, thanks​:+1:t2:
I have a problem where I buy multiple of similar items and then use them to check each other because I dont have the knowledge or background to know if the result is reasonable. As such, I have a number of multi meters and I do think the Fnirsi would be best for what we do here. Simple to use and understand.
I trust my good old reliable Fluke 87 III and confirm capacitance with DATS V3. They always match within 1%. I never sweat the ESR of metalized film poly or foil caps. There are so many other things that are more important that I could screw up way more than a 10th or so of an ohm of ESR.
Just a heads up, I bought mine on sale back in December direct from fnirsi,
for $65.00 USD, and it looks like they still have the same deal.
Thatbis anpretty nice tool for $65. Im trying to resist…
Me too….
I got mine in early Feb, but haven’t used it a ton yet. I did use it to measure every resistor and cap in the Beeny preamp build and it grabs a reading before you can even look up from the clamps to the display. I love that aspect of this meter. Slow responding multi-meters frustrate me, although I admit that’s a selfish first world problem.
Mine is supposed to be here between this Tuesday and next Tuesday
Finally got around to measuring stuff.
First off, the Fnirsi meter is pretty nice, will it last…:man_shrugging:t2: I have an o scope by them, been a few years.
Next up, photo dump of caps…
Safe to say, poly caps are definitely low ESR compared to Electrolytic. If you’re looking for that last little nith of precision, measure your caps and insert data into your sim software.
Thanks for everyone that participated in my quest to learn a bit more about things. Hope someone else gained a little insight along the way.
Have the scope Fnirsi but still haven’t really tried to use it - it been damn near 3 decades since used a real oscilloscope as well as the accompanying brain cells.
