Smaller 150uF poly cap
Have you tared the leads of your dats? Measure your leads with a dmm. If you have a short jumper with bananna plugs short the Dats and test the jacks shorted togeter. I think you are still running up against the limits of what can be done consistently without kelvin leads.
I’ve zeroed the leads and cal’d with the built in 1K resistor (DATS V3) many times.
My leads show 0.6ohm under “Test Lead Resistance”, I assume it compensates for that.
I had to resolder the leads on my DATs V3 a few years ago. The factory solder job was terrible.
Easier option would be to send your caps to Dave and have them measured and compared on the meter with kelvin leads. All caps measured and compared under same conditions.
if only he wasn’t in Canada
Thats a bummer, most precision benchtop meters are mega bucks! But google seems to suggest this with 4 wire kelvin leads - no idea if this is any good or not, but price seems cheaper than some of the caps you are getting - maybe worth a try?
I might pick one up for my next amazon order. Anobody who’s got experince with testing and elctronics please comments on the functionality and capability of this tool. I am at the stage where I can barely hold a multimeter right side up!!!
Problem with that is the SMC leads.
Look at/select the Kelvin Clip option.
audiophiler
solen
jf
jf
mdl
mdl
c
Yeah there is no way a cap is 0%df
I would argue that 0.00006 is not realistic for any cap. I would need to see measurements from a real meter.
OK I See.
What is your measurement set up? Looks nice.
I give.
Solen 160uF 400V
I tried both of my laptops, are you guys getting those little spikes in the measurement?
When I short the test leads, I get this at the end of the sweep…
I know it’s not much, but it’s there, do any of you guys get a clean line all the way to 20K?
Unfortunetly, you are fighting the noise floor of your computer. A Limp Jig might do better Reet’s setup is rivaling if not besting Dave’s East tester a true LCR meter with kelvin leads.
I have wanted that Motu for a while now might be time to pull the trigger.
When I set the upper Z limit in DATS V2 to 20 ohms, I don’t notice the squiggly noise at higher frequencies. But when I reset the upper Z limit to 3 ohms, a bunch of little bumps show up at high frequencies. Here is an example comparison:
55+55+55uF 630V PP caps in parallel at upper Z limited of 20 ohms:
55+55+55uF 630V PP caps in parallel at upper Z limited of 3 ohms:
looks like the squiggles are always there, just that they are squiahed at 20ohms, and magnified at 3 ohmn.
Not sure how helpful this is but here is what I always get when I calibrate the test leads with DATS:
And this is the calibration with a 0.5% 1kOhm metal film resistor:
I don’t have any really large film caps on hand but this is a Jantzen 27 uF CrossCap and a Dayton 40 uF cap:
I ordered an LCR meter that does ESR, supposed to have Kelvin test leads… we’ll see.
If the ESR meter works for you, got a link to it?
