4thtry's 2026 InDIYana theme project - Divide and Conquer
Wouldn’t theic be on tweeter axis?
The center of the bi- sected ribbon is also the tweeter axis. Is Bill taking something else as the mic placement?
Thanks, reet! Attached are the two revised woofer diffraction models, with the mic moved to the correct position. Response above 1kHz now looks much smoother for the 1 meter distance.
Yes, but only for the RD40 measurement. For the woofer diffraction model, the mic needs to be placed on-axis to the woofer, as indicated by reet.
If you enter the RD60 as a single driver instead of 6 you will not encounter the destructive interference. YMMV for actual 1m measurement.
For mic location - Mic should be placed how you measured it, so it should be on-axis with the driver.
Ya, I think I am probably misinterpreting the following note that I found at the end or the “Diffraction Tool” section of the user manual, which caused me to break it out as 6 drivers. Probably better to enter it as a single driver.
“2. Long planar radiator should be constructed by stacking multiple small rectangular drivers with Step = Height.”
In any event, for the actual 1 meter horizontal measurements, I could try putting a pillow over either the top or bottom sections of the RD40’s and then try to re-measure them as individual upper and lower driver sections. This should get rid of most of the destructive interference. Each upper and lower driver section is about 9.5 inches long.
But then I would have to figure out how to do the vertical spin. I would need to put together some type of temporary outrigger platform to hold the speaker in position as I rotated the entire enclosure on-axis to one of the two driver sections. Not an easy task.
You will have to ask Kimmo about it.
Here are the revised RD23 diffraction models, using a single truncated RD40 driver instead of 6 individual drivers. Looks much better now. Also, I did some testing and discovered an easy way to re-do my FRD measurements to significantly reduce the destructive interference problem at 1 meter. The RD 40 cabinet will balance sideways at the center point of either the upper or lower 9.5" long sections using a single 12" bar clamp. And I can block off the upper or lower sections, one at a time, using the same Frost King air conditioner weatherseal that I used to originally truncate the drivers. Just add another 9.5" of weatherseal material and seal it in position with masking tape. No need to use a pillow. So I’ll redo the measurements tomorrow and then start creating the merger models.
Here is the merger tool model for my RD40 measurements, with the tweeters mounted in the center but WITHOUT foam blockers at the top or bottom of the drivers. The model merges a diffraction corrected near field (NF) RD40 measurement with a set of diffraction corrected far field (FF) RD40 spin measurements.
And here is the merger tool model for my Esoteric 7" woofer measurements. The model merges diffraction corrected near field (NF) cone and port measurements with a set of diffraction corrected far field (FF) woofer spin measurements.
And here is my first attempt at a crossover, using data generated from the above two merger models and the unadjusted tweeter frds:
6 pack with horizontal heat map:
6 pack with vertical heat map:
I’ve been listening to the exported digital version of the above xover for a while now and I’d like to share my listening impressions so far.
  1. Bass in the 30 to 200Hz region is a little weak and needs to be brought up in level just a tad. I am listening to just one speaker placed well away from side and rear walls. My model is designed to apply the full 6dB of BSC and I can actually hear the 1-2dB of weakness in the bass level that shows up in the model.
  2. The bulging on-axis response in the 900 to 2kHz region gives the speaker a somehwat forward, honking type midrange quality. This needs to be addressed.
  3. Despite the dip in on-axis at 5kHz, the speaker sounds a little bright and harsh in the 4 to 7kHz region. The directivity is widening and the power response is bulging at 5-6kHz, which, I think, is at the heart of this problem. Probably caused by the RD40’s natural resonance issue; not by the tweeter. My plan is to raise the crossover to a higher frequency and then insert a notch filter on the RD40’s to attack the 6kHz peaking problem.
  4. There is a difference in tonal balance when moving from a seated to a standing position. But it is not as bad as I thought it would be. I’m currently modeling and listening WITHOUT the upper or lower foam blockers in place. The RD40’s are only being blocked in the center by the tweeter. There is a 6 inch long foam blocker underneath the tweeter adapter mounting plate, which forms a small sealed enclosure for the tweeter.
So, back to the drawing board. I think I’ll attack the weak bass problem by moving the woofer crossover a bit higher. Currently at 165Hz. And I’ll attack the treble glare problem with a notch filter.
I made several xover revisions and it is sounding really good now. 18 parts. Very good tonal balance from top to bottom. Razor sharp detail thoughout the mids and highs without sounding harsh. The midrange, which previously sounded shouty, now blends well and does not call attention to itself. I’m very happy with this new version, so I think I’ll start putting together a parts order. Here are a few details on the revision. Let me know what you think.
  1. I pulled down the midrange by about 1 to 2dB with an L-pad (R7/R8). I also moved the lower xover up from 165Hz to 200Hz, which helped things along as well. Now the bass from 30 to 200Hz blends very well with the midrange. Bass is punchy and full, not somewhat thin like it was before.
  2. I moved the upper crossover up from 2500Hz to 3300Hz and then added a 5.6kHz notch filter (L5/C7/R6) on the RD40 to suppress this driver’s nasty self-resonance problem.
  3. I adjusted components to flatten and lower the bulging on-axis response in the 900 to 2kHz region. Sounds much smoother now without the shouty, honky type quality.
  4. I also adjusted the tweeter parts to smooth things out and to match the new lower midrange level. Moving the xover higher helped to flatten the on-axis dip at 5-7kHz, while, at the same time, keeping the power response from bulging too high and creating a conflict. There is a blip in the directivity index at the new xover frequency, but I don’t seem to be able to hear this in listening tests.
  5. The revised crossover meets the Indy 4 octave rule for 3 ways. 200Hz x 16 = 3200Hz. So I’m good to go for the competition.
  6. I should note that I have now completely abandoned the idea of placing upper or lower foam blockers on the RD40’s. I set up a model and attempted to design an xover with the foam blocker version, but it simply would not work. What happened is that the foam blockers dropped the RD40’s sensitivity by about 2 to 3dB at lower frequencies, but then boosted the frequency response at higher frequencies. With the foam blockers in place, the overall sensitivity dropped so low in the 200 to 500Hz region that it became necessary to put a padding resistor on the Esoteric 7" woofer to match output levels. I didn’t want to do that, so the foam blockers had to go!
  7. Even when using a higher 3300Hz crossover without the foam blockers in place, the difference in sound from a seated to a standing position is not very much at all. In fact, the difference is less than the previous xover that used the 2400Hz xover. I think this has something to with installing the 5.6kHz notch filter, but I am not sure.
