The shape of the driver frame, the circular frame with 4 points.
Did you email Beyma about getting a CAD drawing?
No, just attempted it myself.
Step file attached.
6NMFW8.zip (4.2 MB)
Won’t help me but might help others, thanks!
would a DXF help?
6nmfw8.zip (5.0 KB)
Thanks again. Might help somebody else.
My templates are already cut.
Okay, some progress…
I finally cut the rebates for the woofers and tweeters today. Then I finished the driver mountings, the baffle bolt recesses, and added a small angle to the proud top and bottom edges of the baffles.
The tweeters were easy, and I did them last. Honestly, it was really simple. I used a 3.5” Hole saw for the through holes, cut almost through so I could use the center hole for the next circles. Then I used the 110mm hole saw for the outer perimeter of the rebates, only cutting down 0.25”. Then finished the 3.5” from the back of the baffles. A 3/8” rabbet router bit set to 0.25” deep finished the process other than mounting holes. Can’t get easier, as there were no terminal notches needed, funky shaped faces, no stepped frames, or mounting holes near terminals.
You’ve seen what I did for the woofers already, and they pleased me this time around.
Just to show the impedances and T/S again, I’m reposting them here. I could not find the T25M tweeters’ posted impedances earlier even over in the initial thread started at the MAC1 archive.
So, here they are:
Note- the WT2 software reads the delta phase change across 0 as the Fs, when in both tweeters, the Fs is less than 500Hz.
Took whoops this morning.
More to come….
Okay, firstly, the 300+Hz blemish in the HD sweeps is something in my room that currently resonates when I run HD sweeps. I will have to attempt to find the culprit in the very near future. The blemish manifests in both the woofer and tweeter HD sweeps shown below. So- ignore that glitch, please.
(Wish me luck…
T25M FR matches very closely, and the impedance does too as seen previously. The HD, however, is a little variant. For example, HD2 is 5dB diff in magnitude around 2kHz. I did some brief listening with a 6dB highpass cap and tried to hear anything untoward or different between them and really couldn’t tell with any distinct certainty as yet that there was anything truly wrong sounding from the slightly lesser measuring unit. 3rd order is still low enough that it shouldn’t be of concern. The decreasing response of the tweeters should easily make for less HD in the range in question once the response is flattened.
The other thing to note is the relative sensitivity of these T25M tweeters. As you can see- at 20kHz the output here is only about 82dB. I make it a habit of having the same gain level on my preamp and relative mic position when I take FR as that makes drivers comparable. The last measured Wavecor TW30WA22 had an output of 85dB at 20kHz for comparison’s sake. The spec sheet shows 89dB for the Wavecor, which means adding 4dB would leave the T25M’s natural output at 20kHz to be only 86dB. This is fairly low average sensitivity as far as 25mm domes go, and the Beyma spec sheet shows 86dB at 20kHz as well for comparison. I’m currently wondering if any series added resistance will be required to balance these drivers.
Of note: The tweeters did have a 100uF in series for the measurements shown below.
T25M:
The woofers show amplitude hovering around 80dB, so add 4dB like done previously to the tweeters above to yield 84dB relative sensitivity. The good thing is that the baffle step loss appears to already be partially compensated in the inherent woofer response.
The HD peak just below 1kHz is well damped and pretty common in carbon fiber or other woven driver cones. The FR peak at 3kHz is fairly narrow band and should be simple enough to suppress. Hopefully, the second peak at 5.2kHz isn’t more of a pain.
NMF6W:
That was a lotta lotta woodwork. One of the best rebates I’ve seen, barring CNC.
And CNC is cheatin!
Cheers / Robert
Yes, Robert- CNC is cheatin’!
Thanks for the compliment!
And on with more progress…
Okay, this xover model took some fenagling. I purposely did not look at the “Beyma-Recinto NMFM” before I did my simulation, and then followed suit with doing as they suggested, and modeled their circuit.
I will say their phase alignment isn’t awful, and the response isn’t bad per se. We’ve all seen worse than this from manufacturers. The tweeter is run about 400Hz lower before rolloff in their circuit versus mine. There is also a large scooping trough at the xover point, and a pretty dramatic step down in the upper treble. That said, the breakup of the woofer was actually dealt with and suppressed pretty well.
Woodworking=learn woodworking
CNC=learn CAD, CAM, woodworking.
Here is their plan for a cabinet that is only minutely different:
I did estimate with steel-laminate cores for their circuit.
Here is the circuit I modeled, “Inquisidores Sim1”.
The tweeter Fs compensation remains to be seen if it is needed. The xover point is centered at about 1.6kHz, whereas their Recinto NMFM is around 1.2-1.3kHz. As stated before, the woofer has some inherent BSC in its response. I feel this protects the tweeter a lot better than their suggested circuit. You can see I have shown the same acoustic rolloff target in both sims for the tweeter just to see the baseline difference.
The woofer’s dual breakup peaks are targeted more succinctly here, and both are suppressed 33dB+ from nominal magnitude.
Thanks for looking!
With distortion only being down -25db @ 1khz, I’d be a lot more comfortable with your design being down -18db at 1khz
That is another reason the Fs compensation will be tried. I’m a bit hesitant that it will be okay without it for exactly the reasons you state.
It is also a benefit that the decreasing response allows for more output reduction at lower frequencies as it is flattened out. A smaller capacitor can be used in this process to adjust the response.
Okay, I’ve been in xover building mode. Here is the tentative circuit:
Since I have a usual adjustment of between 0.5 to 1.0 ohms addition in voicing, I went ahead and used a 2.7 ohm resistor over the 2.0 the simulation specified. The 0.42mH and 0.18mH were wound to value, and should be the only non-spec values shown. These and the 1.8mH are all 18awg. The woofer 2.0mH is 16awg that I also wound, and the tweeter coil is 14awg foil only because I had them. The 45uF was made using 2x 22uF and a 2.7uF Q4 caps measured to get value. I had some 20uF, but these were smaller. The 0.6 was made by paralleling 2x 1.2 ohm resistors.
Being that this network had 3 shunting notches, I figured the most compact layout would place these on vertical daughter boards next to the main components running down the center. I was able to get both woofer notches on one board, and the tweeter Fs notch on the other. The woofer coil is on one end, the tweeter cap and coil follow, and the small tweeter CR filter and dinky little woofer tank cap are on a small 3rd daughter board.
I used another black block cap because it was good enough for the last build. The size and spec only because it is what was available.
Not sure why I can’t add photos here, so I’ll do that in the next post.
