The GReat DIY Get Together — Iron Driver Competition
It’s official! For the next GReat DIY Get Together, we’re adding an Iron Driver Competition.
The idea is simple: everyone starts with the same driver, and then let’s see what you can do with it. Beyond that, you’re free to get creative (with a few rules).
The Iron Driver
The driver family for this competition is the SB Acoustics SB13PFC-XXX series, including:
SB13PFCR25-04
SB13PFCR25-08
SB13PFCR25-4 COAX
You can choose whichever of these three versions you want to build around.
Driver Budget — $200 Maximum
The $200 limit applies to drivers only!
There is no budget limit on the rest of the build. Spend as much or as little as you want on:
Cabinet materials
Crossover components
Ports
Damping
Hardware
Electronics
Amplification
DSP
Finish
Anything else you can dream up
The idea is to put the emphasis on design and execution, not on forcing everyone into the same budget.
Cabinet Size — 2 ft³ Maximum
The maximum EXTERNAL cabinet volume is 2 cubic feet.
That’s the limit on the outside dimensions of the completed speaker. How you use that space is completely up to you.
Sealed, ported, passive radiator, transmission line, unusual geometry, CNC wizardry, beautiful woodworking, ugly-but-effective engineering… get creative!
Just keep the finished enclosure under the 2 ft³ external volume limit.
Active Systems Are Allowed
I believe this may be a first for Iron Driver, so let’s have some fun with it.
Active designs are allowed.
If you choose to build an active speaker, the system must use one of the following inputs:
Analog RCA
Analog XLR
Digital coaxial S/PDIF
For AC power, use a standard 3-pin IEC inlet.
No USB
No optical/TOSLINK
The goal is to keep the active systems reasonably standardized and easy to connect during the event.
If you use DSP, active crossovers, amplification, or other electronics, that’s completely fair game. Just make sure your speaker can accept one of the approved inputs and be connected to the event’s playback system. Everything must be contained in the speaker.
1st & 2nd Place — Blind Bracket Competition
This is where things get interesting.
The 1st and 2nd place speakers will be determined through bracket-style elimination.
Speakers will be played behind a curtain, so the listeners won’t know which speaker they’re hearing.
No peeking at the cabinets. No identifying the builder. No judging based on the finish.
We’re judging what comes out of the speaker.
I’ll also do my best to get the levels matched as accurately as practical before the listening sessions. The goal is to make this a fun competition while taking the listening comparisons a little more seriously than our normal listening sessions.
The exact bracket format will depend on the number of entries, but the goal is for the speakers to compete head-to-head until we have our 1st and 2nd place winners.
3rd Place — Community Choice
Third place is going to be a little different.
The community gets to choose it.
After everyone has had a chance to see the entries, each person will be asked to select their three favorite designs.
You can vote for any three speakers based on whatever matters to you:
Creativity
Engineering
Appearance
Craftsmanship
Clever use of the driver
Innovation
Overall design
Or simply, “I really want to build one of these.”
The speaker receiving the most votes and did not win 1st or second will determine the community-choice result.
One important rule:
The 1st- and 2nd-place winners from the blind listening competition are not eligible to win 3rd place.
This gives another builder a chance to take home some bragging rights and recognizes a design that the community really likes, even if it didn’t win the blind listening bracket.
The Point
This isn’t about building the most expensive speaker.
It’s not about who has the fanciest CNC machine, the most expensive crossover components, or the prettiest finish.
It’s about taking the same basic building block and seeing how differently a bunch of DIY speaker builders can approach the problem.
Same driver. Different ideas. Different solutions.
And, hopefully, a lot of really cool speakers to listen to.
So start thinking, start modeling, start designing—and most importantly…
