Got most of the parts to refurb the DH-220 yesterday. Replaced all electrolytics, bypassed the big ones with Panasonic PP types, and even replaced most of the film caps on the board since some were looking like they may have seen some heat.
Distortion is surprisingly low. The official spec from Hafler was 0.02%. I’m wondering if I have something wrong in the settings. I can’t run this amp at full power until I upgrade my dummy loads.
I think you should put one on your list to Santa! I had to sell my JBL L112s to justify buying it. But I know I’ll get much more use out of this and it takes up a lot less space!
Your amps are next on the list! I just need to go through the tutorial with this Hafler to make sure I’m setting everything up correctly. Hopefully Scott will see this thread and point out any mistakes I’m making.
I think your measurements look reasonable. I usually wind up with a smaller FFT size (128k) for my standard 1 kHz measurement. I also measure at 5 watts instead of 1 watt. This was originally so I could compare to the Audio Science Review test results by approximating the same conditions. I do agree with the rationale though. At the 1 watt test level, the deviations are almost always dominated by noise rather than distortion while at 5 watts. Anyway, at 5 watts, if I test with a larger FFT size, some of the cheap little class d or other chip amps can get unhappy. Pretty much anything is okay at 128k. When I do automated power sweeps to find the clipping point, I drop FFT size down to 32k so the individual test points go fast and the dummy load can handle a lot more power.
One thing I find helpful is to use dBr instead of dBV for the y axis. That allows setting the peak level to 0 dB on the graph.
I tend to measure THD+N instead of THD - again primarly to compare with ASR’s SINAD measurements. THD+N would have been considerably higher on your Hafler amp at 1 W. In my experience measuring 0.0009% vs. 0.0025% THD spec isn’t that far off. Back then, the better manufacturers tended to err on the conservative side.
Great - thanks for the tips!! I’m still digesting everything covered in Cordell’s tutorial. I hadn’t even thought about FFT size related to power going into the dummy loads.
I also learned there’s some independently developed software that looks interesting - QA40xPlot.
Had a buddy’s Marantz 2270 in last week. Phono stage only output one channel. I ended up replacing all 6 transistors and the input coupling caps on that board. He tells me this is the most sought after Marantz at the moment and I’m not sure why. I did a complete restoration on a 2275 of his a while back and think that’s the one I would rather have.
The same guy with the Marantz gear found a Pioneer SX-828 for me for a pretty decent price. I knew it had some issues. I had been through it once before, but new issues cropped up over time. It turned out to be problems on the tone control/gain stage board. That was an interesting series of issues to solve, including an obsolete FET(an unmatched pair from a previous repair), a flaky Loudness switch (that I broke a pin off when removing), and a 2-sided board that was difficult to get solder to flow through to the other side without cooking the traces off the board. I only lifted 3 of the 60+ on that board. I found the original NOS FETs and a used switch on eBay, but ended up having to take the switch completely apart and scrub it. The contacts were severely tarnished & gunked up just like the original one. After 3 hours of tracing, replacing transistors and reflowing joints, she’s running great now. It hits 70W/ch @ 1KHz, response is fairly flat, and distortion is reasonably low (0.01 - 0.03% THD @ 5W) for something designed in the early 70s.
My buddy TJ knows I can’t resist a nice Pioneer piece. He picked up this PL-15D-II and gave me a good price on it. It’s in very good cosmetic shape, but has a bit of rumble compared to any of my other TTs. I pulled the motor apart, cleaned & lubed it, but it’s not much better. I probably need to replace the old rubber mounting bushings with something more compliant.
Dredging up the old thread - I picked up this Akai AA-810DB today from a guy clearing out some old gear. I don’t know why, but I just like the overall look of this one.1976 was a good year for gear, but this model is fairly rare to find, being the bottom of the Akai lineup and only 10W/ch. Everything works and I was a little surprised it tested as well as it did. A solid 12 watts @ 400Hz into 8 ohms. And despite being about 5dB down at 20Hz and fairly flat from 50-10K, it has a pretty full sound to it.
Stumbled on this “gem” at my local re-store on Saturday. The 10" platter weighs 7.5 lbs!! Tommorrow it goes on sale for 20% off, so if it is still there when I get there, I think I am going to pull the trigger. Kind of dusty and rough looking on the outside, but it is just what I am looking for to complete my classic HiFi system build from the 1950’s/60’s era. This turntable, fully restored, will fit right in.
The previous owner had mounted the turnable in a cheap, plastic Garrard base. I’ll toss that and build a new, very nice, solid Cherry or Walnut base for it. The small, plug in type cartridge mounting shell is missing, but you can pick those up cheap on Amazon or ebay, so no problem there. Before buying, I’ll probably take it over to the plug in testing bench area and make sure that the motor still buzzes or spins up.
That will be a good score. Those Dual’s are fairly complex underneath, but built like tanks!
I think they came set up with a Shure M91 cartridge at many retailers. I have an extra M91 body that needs a stylus. You can have it for the shipping cost.
I haven’t heard either of my Duals play at the right pitch since rescuing them from Goodwill. I think the arm is locked up completely on one of them. I really need to get one of them over to the Fix My Dual guy in Des Moines before he retires.
Nice thing about this table is that both the full owner’s manual AND service manual are available on line. And there seems to be a fairly large community of tech’s servicing and re-building these things. Just got done watching a detailed, 1 hour long youtube video, where a guy repaired a 1019 that took a major hit during shipping, bending the tonearm and plinth mounting assembly. He got it working like new again!
Thanks for the offer, Tom, but I have plenty of cartridges that I can install and try out. I just need to pick up a new headshell “sled” to replace the one that is missing. Amazon sells them fairly cheap. One curious thing that I noticed about this headshell is that the sled and tonearm body have 5 connecting pin positions. But only 4 wires are used to connect the cartridge to the sled! Any idea what this extra pin is used for? Guess I’ll find out tommorrow when I pick up the table.
Picked up the turntable today. I put it on a soft cushion of blankets for the ride home. Uses a big, brushless motor on the underside to spin the massive platter via an idler wheel mechanism. It works OK and spins up to speed without problem, but seems a little sluggish. Think I’ll take the motor apart and re-lube the bearings. Then dissassemble, clean, and lube all the underside mechanical parts. Then flip it over and clean/lube/restore the platter bearings and idler wheel. Should be a fun project.
Idler wheel might need to get rebuilt. The rubber gets hard, and it won’t get to speed. Yours gets to speed, but the sluggishness you describe might well be the rubber on the wheel getting harder than spec, and slipping. I have a vintage (before I was born, and I’m 61) 1010. Motor starts and stops at random, and one channel is out, but still beautiful for a 1963 model auto TT.
Thanks for the suggestion. My wheel looks in very good shape; the rubber is still quite “spongy” and "“grippy” feeling. No cracks, cuts or visible depressions from sitting in one spot against the motor shaft for several years. This is due to the fact that when the turntable is shut off, the idller wheel automatically disengages. So motor shaft flat spots are impossible (good engineering).
There is a place in Canada that sells new idler wheels for the 1019, but they are kind of pricy, so I’m going to attempt a restoration first. DIY style, based on all the threads and vids on the web.
