Looks like several nice Multicomp Pro drivers are on sale:
8” for $29 https://www.newark.com/multicomp-pro/mp011857/woofer-5khz-8ohm-89db-222mm-dia/dp/76AK9650
7” for $33 https://www.newark.com/multicomp-pro/mp011859/woofer-5khz-8ohm-87db-180mm-dia/dp/76AK9652
7” for $23 https://www.newark.com/multicomp-pro/mp011858/woofer-5khz-8ohm-88db-180mm-dia/dp/76AK9651
All look pretty legit.
Newark sent me an email for 15% off my next order but for the life of me I can’t figure out where to enter the code. There is a spot that says “add voucher” but when I click on it the box doesn’t actually appear to enter a code or anything.
Got an adblocker or popup-prevention situation running?
Those 7" $23 woofers model pretty well as a pair in parallel (woofers of a 3 way) in about 1 cuft tuned to about 45 Hz.
Sounds like a possible VersaBox candidate too for 15 ltrs tuned to 47Hz for a single.
FWIW I believe those particular drivers to be a high value at normal pricing, this current pricing is insane.
I’d buy a few but I’m overflowing again.
Which of the MCMs above are you talking about? I have never built with any MCM speakers, but now might be a good opportunity.
The four I’ve linked to recently.
I didn’t know if there was one of them in particular that stood out. It seemed like you were talking about a specific one.
I ordered a couple of the 5” drivers. Should be fun for $20.
I had to use a different browser to get their website to function correctly. Some kind of compatibility issue. Different browser solved the problem.
Grabbed a pair of the 8”, I’m a sucker for 8” woofers.
Ditto, big enough to provide decent bass, small enough for decent midrange.
PE is having a 15% off everything Memorial Day sale.
Use Code: MEMDAY26
I just received an order I place a couple days ago from PE. Will they apply the discount retroactively if I contact them?
I want so many more things from there…
Edit: BTW, the sale appears to apply to the Hypex amps. Given the long list of exceptions to the sale I was surprised it worked. Might be the last chance to get them like that. Haven’t decided to pull the trigger yet.
Edit 2: Is there a reason some of the Peerless drivers are on “clearance”?
In case anyone is interested, there is a pair (not my listing) of RAAL 64-10x tweeters listed on eBay. They were listed for $250 and did not sell and have been re-listed for $200 + $8 s&h. They are located in Montgomery, IL which appears to be near Chicago.
https://www.newark.com/multicomp-pro/55-5670/8-die-cast-woofer-8-ohm-rubbber/dp/95Y2936
I got 4 on the way.
$14.90 ??!!!
Wow!
Dammit, now I will have four instead of two. Hard to resist that driver at normal pricing, to be honest. $15 is ridonkulous.
