You can get rack fans as well, many have built-in temp controls-very nice.
FWIW, I use a cabinet fan system from:
Found Rack fan systems from ac infinity: CLOUDPLATE T1, Quiet Rack Cooling Fan System, 1U Exhaust - AC Infinity
@tajanes How does the home theater ones work - are they standard rack size or how do they get installed?
@KenRhodes do you have any brands in mind?
I’ve not used the rack units. I built these into the shelf pushing air up through the amps -currently a twin fan system with the amp camp amp (also put in a very fine computer air filter underneath the fan unit) It also then pulls air up from my amp that sits below this ‘fan shelf’. Q regarding N. Pass Amp Camp Amp
They are meant (I believe) to pull or push/pull air through a somewhat closed cabinet. Multiple options for the controller: set fan speed, set turn on temp with a selected fan speed, smart settings (adjusts fan speed relative to temp setting)…
Thanks, I saw your other thread. That amp camp amp runs hot in class A. My class AB amp gets warm, but not too hot, but it’s not been in a rack, so that might change
As a thought; my AV preamp ‘runs’ as a pass-through when not in use (so as to pass signal to tv when I’m not playing through my sound system). It runs rather warm on top and sits in a somewhat tight shelf. I’ve placed two small heatsink plates (bought through Amazon, approximately 6 x 3.6 x 0.6 inches) on top over the hot area (not over any vents) of the preamp and they do help in pulling and displacing heat.
If you have spare rack space, pro contractors often choose to leave a blank space between heat producing components to give them “room to breath”. You can buy filler screens to fill the gaps. Some are solid, I have mesh filler blanks.
I am making custom rack - these will hold a bunch of different components. I do also have a growing assortment of pro gear with rack ears, and the idea of going with rack rails for the pro gear seems more efficient. I haven’t used rack rails or stacked pro gear, hence the questions and stuff!
Ani - 3/4 oak is more than suitable for making the rack rails. You can easily drill & tap it for standard hardware. It’ll even hold up to some abuse if you stack and support everything well.
Tom, did you make any by any chance?
We built two 16 space racks when I was working with a country band in the 90s. One for the main amps and the other for monitor amps and power distro. That main amp rack was ~250 lbs and survived over 600 trips up & down our rumble strip truck ramp.
